Show only
Search instead for
But even if you create the project with Copy Design, there are no files in the folder. It will have the same effect as doing it manually.
Really what you want is the ability for the Project Properties to be pushed to the file when the file is added to the Project folder. This way it doesn't matter what workflow added the file to the folder, this will happen. Correct?
