Enhanced Dialog Window at Vault log in
I'd like the Server pull down to be enhanced to have greater than the last seven servers accessed.  I would like that list to keep all servers accessed in a scroll list.  Being able to add a list of servers would be nice too instead of having to type the value the first time....being able to import a txt file of server values.  What would really be nice is to be able to also add info to a server listed.  In the image for example, I'd like to be able to add the text "Canada Server" to identify PCD034A12.  Also include the ability to pin (like in the Inventor or Word file open screen) any so that they remain at the top of the list.
This is required when logging into and maintaining multiple AVFS.  This enhanced field would also be helpful for the Vault value as well.
4 Comments
Andy.Spivey
Hey Tim,
You may be able to achieve part of this (pre-populatin the drop down) by editing the LoginHistory.XML file under C:\Users\%LocalUserName%\AppData\Roaming\Autodesk\VaultCommon
-Andy
tfrascone
There are seven of these Server Names in the xml.  No others can be added with further server values.  Once another is added the whole list dissapears from the Vault log in pulldown.
 <Server>
      <Name>ServerName</Name>
      <Vaults>
        <string>PxxxxxHQ</string>
      </Vaults>
    </Server>
  </ServerHistory>
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
