Encrypt sa and Vault Admin passwords in the backup script
The Admin Password is written in clear text in the backup script.
This also is true for the sa credentials if a different account than the default is used.
The wish to find a way to avoid putting these passwords into a clear text file to conform with security policies.
Two possible workarounds are documented in this article.
Encrypt Vault Administrator and SQL Administrator password in Vault backup script
3 Comments
Richard.Rankin
Autodesk Support
Another possible solution would be for Vault to support using an SQL Backup Operator purely for the backup.
RajSchmidt
I agree with you. Although one could argue that you have quite different problems if an attacker gets as far as reading the backup script.
this functionality is very useful. it should be added.
