Drawing Lists and batch plotting
Vault NEEDS an easy "one click" method of being able to produce drawing list (with options to show the "tree" structure) and to also print or export that list based on the highest level assembly required.
Yes I know there is the batch plot method, but why does it require so many steps? And it's only good for plotting.
It should be something as simple as RMB on a drawing file with a drop down selection list of print/export drawing list, batch plot all associated drawing files, etc.
4 Comments
YounesYammouri
Status changed to: Accepted
ihayesjr
Implemented in 2026.1 Update
nathan.quilla
This was a bad change, I can no longer batch plot the items in my eco. It has taken a one click process and turned it into a 250 click process where I have to add every drawing that changed manually. 0/10 would not recommend updating to 2026.1
justin.whaley
I agree with Nathan.Quilla. 0/10
