Decrease Project Sync time interval setting
When using Project Sync for Vault to sync to FusionTeam or BIM360, and choosing the Interval option, the minimum allowable interval is 8 hours.
It would be great if this could go down as low as 30 minutes, or even less.SyncSettings.PNG
1 Comment
ihayesjr
You can set the minimum to 1 hour using the following steps with Vault 2019.2 Update and Vault 2020.
  1. Open Windows Explorer and navigate to <install dir>\Vault Professional 20XX\Explorer.
  2. Edit the Connectivity.VaultPro.exe.config file with Notepad
  3. In the appSettings section add: <add key="ProjectSyncMinimumFrequency" value="01:00:00" />
    1. Format is <add key="ProjectSyncMinimumFrequency" value="hours:minutes:seconds" />
  4. Save the file
  5. Launch the Vault client
  6. Edit your Project Sync configuration schedule and enter 1 into the hour field.
1 hour is the minimum you can configure this setting for. Anything lower will default to 1 hour.
