Data Standard - Override the New command for Custom Objects
It would be nice if Data Standard could let you override the New command for Custom Objects.  The API supports this feature, so Data Stanard just needs to add the API hook.
Under the current implementation, Data Standard lets you add a new command for creating a Custom Object, but the default New command is unchanged.
My proposal is for Data Standard to override the New command instead.
4 Comments
ihayesjr
philip.s
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
