Create Thin client Link from within Thick Client Change Orders
I often share Thin Client links of Items to others and/or store the item links in an ERP system when closing ECO's. it would be very helpful if I could generate a thin client item link from within Vault Professional Change Order without having to open the thin client.
Ideally I would like to establish a custom naming convention that grabs properties for the Link name Also.
3 Comments
ihayesjr
@Gene.R
You can already create a Thin Client link for a Change Order.
Select the Change Order, in the File menu click Send -> Send Link
It will open an email with a thick and thin client link.
Gene.R
@ihayesjr
The Link is for Items while inside of a Change order records.
Right Click on multiple items an select send link
When I Close ECO's I generate thin client ITEM Links for our ERP system.
In the Thick Client I currently I have to leave the change order environment > perform an operand search on items > send link. Currently the only address to the is presented, I would like it to also be named as "PartNumber" Rev A.
In the Thin Client  it is slightly better, I still perform an operand search in the Items > carefully tick each of the boxes > share to email. I then get the name as a separate line and the address below.
I am then using a batch file to create named windows shortcuts
If the thin client link address was exposed in the Thick Client property set that would be sufficient too.
I am open to other workflows also.
Gene.R
In the previous Thin Client I used to drag and drop from an Item search result
