Copy design without downloading unwanted files
When I make a copy design of a simple assembly (composed of 2 parts and one drawing), even if I set the parameters to those files only, it takes about 5 min because Vault downloads on my computer all the files (~700) needed for the mega assembly where my simple assembly goes.
Couldn't that be simpler and faster?
I have been told by my local Autodesk support that "Inventor needs all the files to be able to correct the whole without compromising other links"
I still don't understand why, because it works very well when I make a simple copy-paste in Windows, and it's very quick!
4 Comments
ilotey
I agree with this.  When you have PART-A that is used in multiple assemblies, if you make a copy design that includes PART-A, it will download every assembly PART-A is used in, even if those assemblies are not changing.
This almost seems more like a bug fix than a feature request.
YounesYammouri
olearya
Implemented in Vault 2015 R2 - Copy design no longer downloads files.
JBerns
I see the issue has returned again of downloading/sending of hundreds of files when using Vault's Copy Design on a drawing.
The number of files downloaded/sent is increasing with every drawing that we copy.
We are using Vault Basic 2022.4.
Is this scheduled to be fixed?
