Configuration tools
Configuration tools
It would be great if we could have a new tool similar to copy design that worked with iLogic rules within Inventor files.  This tool would copy a template within vault to a new location, allow users to edit a form of parameters within vault and would run a top level iLogic rule (prob via itriggor).  Currently users need to copy the template using copy design, open manually in inventor, configure and check in.  I would like to be able to do this so that non inventor users can run a configuration via inventor without realising it using only the vault environment they already know.
3 Comments
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
