When you open the Change state dialog, all files are selected (checked). If you re-use standard parts a lot, you always have to de-select (uncheck) all files and then select the ones you need to change state.
Therefore I would like to have an option in the settings menu to choose if I want them all checked or unchecked when starting this function. It will save me time.
Additional benefit is the reduced chance to make an unwanted revision on released parts. When you go from a released state to work in progress and accidentally you have to many files selected, they all get an unwanted revision update.
