Change Approval Process in a CO
It would be great if we could change the unanimous approval setting in an existing change order.  There are times when the routing should be unanimously approved and other times when it should not.  Currently, I believe we need two routing definitions to support this. It would be nice to offer this setting in the Open state for a Change Administrator to change when needed.
Mark
3 Comments
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
