Chane Order Properties
Would like the ability to capture the username of whomever submits a Change Order to each phase, and be able to save that with the ECO.  Right now about the only thing we have is "Last Updated By".  On a closed ECO, that will always be the Change admin.  What I'd like to see is, specifically, who submitted the ECO to Approved... and have that value STAY with the ECO.  One concern I've heard here from folks is, how do we know WHO approved these changes?  All we have is a UDP with a list of values... but anyone on the routing can change that value.  If there were a property that got set at each sumit stage, and stored... that would answer these concerns.
4 Comments
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
cbenner
Interesting... I had forgotten this idea until someone brought it to my attention and asked about it.  It seems to have been marked accepted, and then Archived 5 years later.
Well, it's back boys!  And this time I've been approached by someone who not only needs to be able to have a change order UDP usable outside of the change order, but they would like to be able to create an ECO property that has an enforceable value, such that the ECO cannot change state unless the Value is set to "X". Any way to open this back up and get some more comments coming?
