When the Job Processor creates a design representation (e.g. DWF, PDF, or other derivative outputs) from a source file, the check-in or state change comment of that source file is currently lost. The generated representation either has no comment or only a generic, job-generated entry.
It would be very helpful if the comment entered during the check-in of the source file were automatically transferred to the newly created representation file — for all target file variants (DWF, PDF, and any other output format produced by the job).
This would preserve the context and intent that the author documented at check-in (e.g. revision notes, change reasons) right where it is most useful, without requiring a manual second step.
Preferred behavior: when a design representation is generated by the Job Processor, the check-in comment of the source file should be copied into the comment field of the created representation file. This should apply consistently across every target file type, so the original context travels with the derivative regardless of output format.
