Better Engineering Change Order Dialog
-Make Detaildescription (1) higher and Properties (2) lower.
Now when i change the height of the window, the height from the Propertiesfield (2) is also changed.
It would be better if the height of the Detaildescription (1) is changed and not the Propertiesfield (2).
4 Comments
YounesYammouri
Status changed to: Accepted
YounesYammouri
The product development team is considering the feedback of the community and have implemented some of this feedback in the development pipeline. You are encouraged to join the Autodesk Vault beta program to get a view into what’s being implemented. We appreciate your feedback.
Younes Yammouri
Autodesk Vault Product Manager
YounesYammouri
This Request is implemented in Autodesk Vault Professional 2016.
jdkriek
This results in a massive Detailed Description field unless you shrink the entire Preview Pane.
At no point can you see more than three ECO properties without having to use the scroll bar.
