Basic workflow problems
Just wanted to suggest an area of improvement in file management -
In my workflow, I try not to keep any files locally that I'm not working on. If I'm working on something, I'll check it out of Vault, make my changes, then when I check it in, I have it delete the working files.
The problem occurs when I don't want to save changes. I might check out files thinking I'm going to change something, or I might open them to check something, or I might open them to play 'what-if' games. When I'm done, I don't want to save them but I need to get rid of the working files. My choice is one of several workarounds like go to Vault and 'undo checkout' which does give me the option of deleting the files. It would be nice if I had a 'undo checkout and delete working files' checkbox when it asks me if I want to save the files or not.
Another place that this management falls apart is when you have more than one 'parent' open, either two assemblies that use the same child, or an .idw and it's .iam. You check the first one in but it won't delete any files because one of them still needs to stay open. Or if you check them in in the wrong order. When you are done, you're left with working files locally and no easy way to clean them up. To clean this up I go thru the folders and delete any files that are in Vault by looking for the circle. Very time consuming. A utility that makes this easier would be nice.
3 Comments
ihayesjr
Status changed to: Accepted
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
