Autoloader Redo Folder for all files removed due to broken relationships
Description
Autoloader allows user to remove documents with issues after a scan. These documents remain in the same folder as the documents without issues that are loaded into Vault
 Impact
Reloading the documents with issues requires finding and fixing broken relationships\x-refs etc.
The documents with issues are stored in the same folder as successfully loaded files.
Requires exporting the report of issues and manually extracting the files for the Dataset for reprocessing
Severity
High/Critical
 Solution
When files and their associated files with issues are removed from the scan list, move these files to a redo folder so the User can repair the broken relationships\x-refs and then Autoloader this delta folder.
3 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
