Autodesk Vault TC Model States Viewer
5 Comments
ihayesjr
Status changed to: Archived
Thank you for posting the idea. We will pass this idea request on to the Autodesk Viewer team.
ericb5LD5J
When we select an IPT or an IAM with Model States and go on "View" it shows us the [Primary], which is ok, but the problem is that there is no way to change Model State.
We've had issues where the production look at an assembly to see how to assemble it, but built the wrong thing since they could only see the [Primary].
I tried using DWFx, but it is laborsome, and I have had issue where I create a DWFx from a IAM and when I save the IDW, the DWFX automatically switches to a IDW, so I always need to double check and start over when they get mixed up.
Tags (4)
maschmeyer
Dear @ihayesjr,
kindly asking when this feature will be available?
ihayesjr
ihayesjr
Inventor needs the ability to export the Model States into a DWF file first.
See: Model States in DWF files - Autodesk Community
