allow download and view for only "released" life cycle states
We have two different work flows, one for standard parts that are highly controlled and one for custom parts that are usually only used once for a job then not changed again but reused of future projects.  The problem we are having is that we do not want the people who are working on custom parts to have access to any standard parts that are currently in work in progress (WIP).   Sometimes parts that are WIP are actually in some larger assemblies and if a user does a "get" of that larger assembly and its children, they will get the WIP version of those parts.  I can deny downloading for them on WIP parts but the problem with that is that vault does not know to go back the most recent version that that user does have permission to download.  What vault does is looks in the user's working folder and deletes that file (if it exists in their working folder) and tries to download the most recent version but the permissions denies the download, so then there is a missing part from the upper level assembly.    There also is not a way to download a previous version manually because the most recent revision is work in progress.   I could also prevent them from seeing WIP parts but Vault hides all revisions not just the work in progress revision.
There needs to be a way for users to be able to download the most recent "released" version of files, not just the most recent.
10 Comments
pbrinnel
This is an important issue. Well put!
pjrichmond
Community Visitor
This would be a huge improvement to our workflow! Would love to see this change implemented.
ecloutier
Community Visitor
without this additional functionality Vault is useless to 90% of the engineers at our company.
jblack6ENUY
Community Visitor
This would be a great change!
vphan4XD9Q
Community Visitor
SO SURPRISE! HOPE IT WILL BE SOLVED SOON BY AUTODESK IN NEW UPDATING PACKAGES.
ihayesjr
Status changed to: Archived
The product already does this. It is based on how the user performs the Get command.
I had a conversation with @lcourtoisHLP8H on this.
ProductivCADUser
This would be helpful for us too.
Which “get command” do you mean?
Can this be used in the thin-client?
ihayesjr
@ProductivCADUser
The Get command inside of the Vault Client can be used to get the Released versions of files.
The Thin Client does not download CAD file structures with the native file. It is meant to download visualization files only.
Nathan_Gallant
Having control over user access like this would be very helpful through the lifecycle definitions rather than in the user's get dialog. With the current Vault functionality there is nothing preventing the user from getting the wrong version of a file accidentally. It also forces the user to spend more time being explicit with get actions instead of performing bulk downloads. In our environment, having administrative control to limit access for specific lifecycle states without hiding all previous file versions would be hugely beneficial.
Gene.R
This also would apply to ITEM users on the shop floor that have a full client.
in the thin client we can now limit to only see Items only, released items only, and latest version only.
in the full client if you set it to only allow released then they are locked out of all previous versions when there is a work in progress.
