Automatic flat pattern exports of sheet metal parts to DXF in Vault are a very interesting feature.
I would like to add a criterion in their configuration options to select the model state to be used during this export.
This criterion would allow choosing the default model state that should be activated for the export; if it is inaccessible, then the "Master" state would be selected instead.
This would make it possible to handle, for example, cut and machined parts requiring an allowance for material removal, which may have a model state such as "As-cut part," or cases where the cutting contour is managed within a specific model state.
The default parameter for this criterion would be "Master," and the administrator could enter a specific model state that would then take priority.
Thanks.
Vincent.
