Idea / Request
Many customers implement an Item workflow in Autodesk Vault. In these environments, designers often create additional drawing files that reference the same model—e.g., drawings created purely for views, layouts, simplified presentations, manufacturing variants, or internal documentation.
Today, when a model is assigned to an Item, Vault attaches all referenced drawings automatically (as intended from a dependency perspective). However, this behavior also attaches “view drawings” and other non-master drawings, which can create noise and administrative overhead.
Problem
If a model is referenced by multiple drawings (including drawings created only for views), all those drawings are attached/listed under the Item.
This becomes a major cleanup task for users, especially in mature Vault environments with many historical drawings and view-based drawings.
In most cases, the user wants exactly one drawing to be considered the “main” (master) drawing for the part/assembly, and the other drawings should not drive compliance checks, “up-to-date” validation, or downstream jobs.
Impact
Excessive manual cleanup and confusion for end users
Harder to maintain a clean “source of truth” on the Item level
Increased risk of running exports/jobs (PDF/DWF/DXF/STEP, etc.) on the wrong or irrelevant drawing
Slower adoption and weaker trust in the Item workflow due to cluttered associations
Proposed Feature
Introduce a drawing classification concept for Item-associated drawings, such as:
Primary Drawing: The main/master drawing for the Item (user-selectable)
Secondary Drawing: Additional drawings referencing the model (views, layouts, variants, legacy, etc.)
Expected Behavior
When assigning a model to an Item, Vault can still detect and list all referencing drawings, but allow marking one as Primary.
Users (with permission) can change which drawing is Primary.
Provide administrative options (ideal for system architects) to:
Ignore Secondary drawings when validating “up-to-date / compliant / latest version” rules
Exclude Secondary drawings from Job Processor tasks (or allow job rules that target Primary only)
Clearly identify Primary vs Secondary in the UI and APIs (filters, columns, icons)
Benefits
Significantly reduces Item cleanup effort
Improves clarity: one Item → one primary drawing (when desired)
Prevents incorrect exports/jobs and improves automation reliability
Better user experience and stronger adoption of Item Master workflows
