Add authentication for Azure users
More and more users do have hardware that is not domain joined (Windows Active Directory). These users authenticate business applications as an Azure user. It would help if Vault supports Azure users.
6 Comments
ihayesjr
@arjenblok
Have you tried this? I believe this should already work if your Vault Server is part of the domain that authenticates the user to Azure Active Directory, the user selects Windows Authentication and it should give them access.
arjenblok
@ihayesjr
Using Windows Authentication on a Vault server in Azure is possible as long as the clients are domain joined. I see more and more customers without domain joined machines and in that case Windows Authentication is not possible. Could the new Autodesk ID login solve this?
ihayesjr
Yes, the Autodesk ID integration in Vault 2022 should solve this request.
rpertusio
Background:
  • PCs are connected to Azure AD (Azure AD Joined)
  • User accounts and groups still live in on-premise Active Directory (AD), synchronized to Azure AD using AzureAD Connect
    • Users still use AD credentials to access on-premise AD apps
    • Users can SSO to servers/shares  (including file shares, printers, 3rd party apps) because PCs still have line-of-sight to domain controllers
Limitation:
  • User/Group management in Vault Administrator fails with an error ("You must be authenticated to a domain in order to perform this operation.")
Expectation:
  • Vault should detect the domain (example .NET command)
    [System.Net.NetworkInformation.IPGlobalProperties]::GetIPGlobalProperties()
  • Vault should use the current Windows Authentication credentials/Kerberos in that domain to manage users/groups
Supporting documentation:
Tags (5)
rpertusio
Additional commentary:
AutoDesk Engineers can implement it this way...
  1. Detect the proper domain
  2. Pass that domain value to:
    pwzTargetComputer   (a string that's part of DSOP_INIT_INFO)
    https://learn.microsoft.com/en-us/windows/win32/api/objsel/ns-objsel-dsop_init_info
If necessary (to avoid risk), maybe add an Option in the settings such as: "[x] Use alternate domain lookup method"
I verified that it 'works' by entering a 'target' of my domain ("example.com") in this 3rd party AD Object Picker .NET app: https://github.com/Tulpep/Active-Directory-Object-Picker .  I'm able to pick users/groups from my domain without any additional authentication prompts.
rfenyves
Vault needs to be able to read users from existing user groups in Microsoft Azure.
