Show only
Search instead for
More and more users do have hardware that is not domain joined (Windows Active Directory). These users authenticate business applications as an Azure user. It would help if Vault supports Azure users.
Have you tried this? I believe this should already work if your Vault Server is part of the domain that authenticates the user to Azure Active Directory, the user selects Windows Authentication and it should give them access.
@ihayesjr Using Windows Authentication on a Vault server in Azure is possible as long as the clients are domain joined. I see more and more customers without domain joined machines and in that case Windows Authentication is not possible. Could the new Autodesk ID login solve this?
If necessary (to avoid risk), maybe add an Option in the settings such as: "[x] Use alternate domain lookup method"
I verified that it 'works' by entering a 'target' of my domain ("example.com") in this 3rd party AD Object Picker .NET app: https://github.com/Tulpep/Active-Directory-Object-Picker . I'm able to pick users/groups from my domain without any additional authentication prompts.
