Did you just recently install a 2019.3.x update?
@jjstr8
* did you restart the server?
* can you try repair the Vault Installation: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Uninstalling-and-r...
* Also be informed, 2019 is not a supported Vault Version, so please consider upgrading, so you can log support tickets as well under www.autodesk.com/contact-support
I've been told that there were asp.net logs that needed to be cleared. After that, the affected services were able to be restarted.
