Vault Professional 2017 - licensing crash
xdumontnti
Message 1 of 30
xdumontnti
When starting Vault Pro 2017, it ask me a serial number or network license.
I chosse Network License, set my lmtool server and nothing append and the process Connectivity.VaultPro.exe disapear.
I try with serial number, same behavior.
I try this on a Windows 7 64 bits + Windows 8.1 64bit, same behavior.
Any idea? Thanks in advance
Replies (29)
Message 2 of 30
DarrenP
i haven't installed Vault Pro 2017 yet so i can't really say
but was your license file updated to include Vault Pro 2017
DarrenP
Message 3 of 30
xdumontnti
Yes my license file is up to date, lmtools is installed from the R2017 source. I can see the vault 2017 licensing in my licence file
Users of 72400VLTM_F:  (Total of xx licenses issued;  Total of 0 licenses in use)
But it's not related to lmtools or license file because if I try to put another inexsting servername, I get the same behavior (normally as the help said, it must show me a dialog box to select another server or licence file, but nothing.
When I try this
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
nothing append. No log.
If I ask to enter an serial number, the system just close.
Message 4 of 30
DarrenP
it must  be something new with 2017
since i haven't installed it yet i can't really say
DarrenP
Message 5 of 30
ihayesjr
Are you installing the client in English?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 6 of 30
xdumontnti
Yes.
I try English VLTP_client on English OS (win 7 sp1 64b)
English VLTP_client  on French OS (win 7 sp1 64b + win 8.1 64b)
Actually I'm testing to reinstall C++ Runtime:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Message 7 of 30
xdumontnti
And before those c++ test (in progress) I force the Network license:
I set "_NETWORK" in "C:\ProgramData\Autodesk\CLM\LGS\569I1_2017.0.0.F\LGS.data".
It don't ask about license type, but still quick exist just during loading the login UI.
Wait on C++ reinstall (if I remove all C++ Runtime, I get the log-in dialog)
Message 8 of 30
ihayesjr
Did you use the Download or the Install Now option from your account to install the client?
Irvin Hayes Jr
Autodesk, Inc.
Message 9 of 30
xdumontnti
I try with full download (through download manager)
I try with install now
No change, the only things I didn't try is to download through browser.
I uninstall all c++ Runtime => no more crash
I reinstall following KB article => crash again
On your side, no crash?
Message 10 of 30
xdumontnti
I found :
In Windows parameters, in "Region and Language", in the tab "Formats", I was in "French-Switzerland" FR-CH (my country with our default date separator, decimal separator, etc...).
French-Switzerland => crash
French-France => no crash
English-United States => no crash
The key point in the registry is:
HKCU/Control Panel/International => LocalName
If LocalName = "fr-CH" => crash
If LocalName = "fr-FR" => no crash
During the Beta => no problem, with older release => no problem, is it a bug?
Message 11 of 30
b.graaf
Same here: region settings Dutch (Netherlands) and Vault crashes directly after start; no way to reach the login window.
Region settings to English(united states) and no problem.....
Message 12 of 30
ihayesjr
No need to create a support case.  We are looking into it based on this thread.  Thanks for the information, it is very helpful.
Irvin Hayes Jr
Autodesk, Inc.
Message 13 of 30
ihayesjr
As a temporary workaround navigate to the C:\Program Files\Common Files\Autodesk Shared\CLM\V3\MSVC14\resources\adlm directory.  Copy the "fr-FR" directory and paste it into a "fr-CH" folder.  This should address the French-Switzerland setting.  As an alternative you can copy the "en-US" folder to the "fr-CH" folder.
Irvin Hayes Jr
Autodesk, Inc.
Message 14 of 30
xdumontnti
It work Smiley Happy Thanks a lot for this quick support answer.
Have a nice day.
Message 15 of 30
Dan_Margulius
Hello
Same problem here, but we are in Israel
What should we copy and in to what?
Dan
Message 16 of 30
xdumontnti
Copy en-us to your corresponding language code
In order to know what are your actual language code:
- Go into registry (type regedit in a run windows).
- Navigate to HKEY_CURRENT_USER\Control Panel\International
- Look at the value "LocaleName"
PS: If you are not familiar with windows registry, be really careful and don't edit it, just show.
According to the following article, for you it's probably he-IL
https://msdn.microsoft.com/en-us/library/ee825488(v=cs.20).aspx
Message 17 of 30
Thanks for your posts.
I'm based in the UK and have the Vault Professional 2017 client startup failure.
Following the suggestions, I checked the registry and my locale is en-GB. I created the folder C:\Program Files\Common Files\Autodesk Shared\CLM\V3\MSVC14\resources\adlm\en-GB and copied the content from en-US
I can now start Vault Pro successfully.
Thanks again,
Paul Thurgood
vlt systems ltd.
Message 18 of 30
Patrick.De.Neef
Hello
anyway we can fix this locally in the client install sources ?
I have over 250 systems to install with a mixture of en-GB, nl-NL, be-FR (Belgium, multi-lingual state 😞 )
Regards
Patrick
Message 19 of 30
ihayesjr
Patrick,
We are investigating the problem to see how we can get it addressed.  I will respond to the thread as soon as possible.
Irvin Hayes Jr
Autodesk, Inc.
Message 20 of 30
It may be possible to create a Vault Professional 2017 client deployment and specify the extra folders within the deployment. I am unable to test this for you at the moment.
Paul.
