Is it possible to install vault server on Linux os?
Solved by DarrenP. Go to Solution.
Solved by Uffe_Bak. Go to Solution.
As I have just replied in a direct email for the escalated support case, on your question if Vault Server can be installed on Linux:
The answer is No - it requires a Windows Operating System, as shown in the system requirements:
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/sfdcarticles/sfdcarticles/S...
I do know that there are Windows "Simulators" running under Linux, but it will not be considered a supported platform.
This means if any issue was detected, you would need to reproduce the issue on a supported Windows Environment, making the exercise a little redundant.
I hope this answers your question.
If not - please do let us know.
Best regards
Uffe Bak
Technical Support Specialist
Autodesk Ltd.
probably not since Vault requires Microsoft SQL which only runs on Windows
DarrenP
No
That's not good, the future of servers lies with Linux.
And I also hope that this future will also come for client computers.
I’m sure Autodesk will provide a Linux version. As soon as you buy a few thousand licenses. 😉
