Currently you must have full admin rights to set up a new sync with BIM360 using the Data Connector. It would be nice to allow users that do not have full admin rights to set these collaborations up to ensure nothing is mistakenly changed.
I feel like the entire collaboration between Vault and BIM360 needs to be looked at especially with the push to move to ACC. Having to set these up one at a time for each project is very time consuming depending on the number of projects you may have. You should be able to set up a template and logic that will look at BIM360 and Vault for a project to begin the sync. This is especially concerning when both Vault and BIM360 folder structure is standardized but you cannot set it up to follow the logic for each project.
Thanks for posting the Idea.
You do not need full administrator permissions to setup Project Sync. You can have the Configuration Administrator role and setup Project Sync. Or, you can create a custom role with the correct permissions to setup Project Sync.
Can you please tell me what permissions are needed then? I cannot seem to find the right combination.
Look at the out-of-the-box Configuration Administrator role.
No luck.
It allows you to get through setting everything up but when you try to Apply user gets a 303 error.
This sync could be very powerful but there is a lot of admin setup that would need to be done for all folders that you want to sync. If you are not doing many projects that may be acceptable but when you do 100+ projects a year setting these up for each is very time consuming.
Could we maybe get something in the right click context menu to start sync? This would be of course after the initial sync rules have been defined. It would be great if an admin could set up the rules to follow and allow any user to start the sync based off what the admin has set up.
What version of Vault are you using?
I am not having any issues using Vault 2023 and a user with the Configuration Administrator role.
By the way, if the folder is already setup to sync, the user can select a file and in the menu File -> Upload to Cloud Drive.
In Vault 2022 the permission is called "Vault Set Options", but then your users with this will also be able to affect your Lifecycle definitions, etc. You can make a custom role that takes this individual permission instead of assigning the user with a broader Config. Administrator role.
Edit: @tschaeferZNBXX go to Tools > Administration > Global Settings > Manage Roles > New Role > scroll to the bottom and ADD "Vault Set Options". Save it however you'd like, then assign this to your user/group.
The settings in the Vault Settings tab are all or nothing. There are not permissions for each setting. The user needs the Configuration Administrator role to do this task.
After you gave the user the config role, did the log out and back into Vault?
@ihayesjr - We are using Vault 2021 Pro right now. Will be upgrading to 2023 soon.
I am really concerned that it is all or nothing with this as now I have to give a user that may accidently change a admin setting unexpectedly. This is pretty concerning because if they mess with properties and mapping it will reindex the SQL server. That could cause us a major slow down for users (approx 700) and our Vault is fairly large (17TB roughly).
Could there not be an out of the box role for VDC admins that could control this?
I think I am wrong for the "All or nothing statement".
You may be able to do this by creating a custom Role and removing permissions you find in the Configuration Administrator role.
However, the user will need more than just the Configuration Administrator role. They will also need at least a Document Editor role.
Another hint into customized roles. Any time you see a "Set" and a corresponding "Get" permission. You will need both permissions. You can't "Set" what you can't "Get".
Thank you Irvin.
I will test that and see what comes from it. My biggest concern is users changing things they are not aware they are that are not Vault admins. It could really mess up lifecycles, permissions, properties, etc.
Please vote for this idea:
https://forums.autodesk.com/t5/vault-ideas/new-role-for-cloud-drive-sync/idi-p/11516305
The minimum permissions I found (through much back-and-forth testing) for a custom role to allow your users to add cloud drive mappings are these:
