- Mute
- Permalink
- Report
What is the most common reason for the "Failure calling web services..." error when trying to run a nightly backup of vault via a batch file run with task scheduler?
I have two servers, as far as I know I setup Win server 2012 R2 and SQL 2014 the same exact way on each machine. One has been running ADMS Server 2019 (Basic) for the last year, the new server is running ADMS Server 2020 (Pro), clients are now live on this server, everything is working except the nightly backup. I have been logging in remotely every night and manually running a full backup through the ADMS console. Really want to get the scheduled task working again.
I have attached a backup log file to this post, I redacted the server name and IP. I also attached the bat file I am using for the backup.
On the server CMD is set to run as administrator, and the scheduled task is set to run with elevated privileges.
Is this an issue when moving from Basic to Pro, or am I missing some kind of setting in my default website or SQL?
While the server is local to our facility, corporate IT is located at another site and they control the VLAN for these servers, could it be some kind of setting on their VLAN or is this a localized server issue?
