Hello colleagues, I wanted to know if you can see the total size of the files from the vault client.
Solved by ihayesjr. Go to Solution.
You can only see this on the Vault Server.
Another question about the size of file versions is reflected in the total size?
You can add the File Size column to the grid if you want to see a specific file's size. This will be the size of the individual version of the file, not the size of all versions.
