SAP TO VAULT INTEGRATION
Boopathi_Sivakumar
Boopathi_Sivakumar
Hello All,
one of our customer are actually using SAP ERP . Now they are moving into Vault. They have their customer details in ERP(order number, customer name, project title, approved id etc). What they are expecting is if i give order number in vault it should fetch all the details from the ERP and it should place the details in the title block. I think we can Map the details form Vault to title block,Is it possible to fetch the details from ERP to Vault properties. Or is there any other methods to do this.
Thanks!
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
rtowne72
Hi @Boopathi_Sivakumar-
I suggest you take a look at Jitterbit.  They do integrations between MRP/ERP/PDM/PLM products.  I spoke with a fellow from Jitterbit two years ago at AU about integrating our iSeries with Vault.
If you try to manually do this it will be a long road but can be done via the API, that is why I recommend Jitterbit.
Good Luck!
Rob Towne
Sr. Engineer/CAD Manager | A.L.P.
Inventor/Vault Professional/AutoCAD
tschaeferZNBXX
A company I worked for in a previous life used SAP and Jitterbit.  It worked pretty well.
A few things to consider though.
1. Will Vault and SAP talk bi-directional?
2. How often will Vault feed information to SAP?
3. Be sure the mapping is correct in Vault UDP's.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
thomas_otto
Hello Mr. Boopathi,
that's not a problem.
The Vault Prof. SAP Connector fron CIDEON can this .
https://www.cideon.de/integrationen/vault-sap/
https://www.youtube.com/watch?v=3J8s3VraZpY
You can look at Jitterbit
You can look at Coolorange Powergate
My other office is using an add-in made by CADSPEC  that exports fields to import into SAP
The SAP Platinum Partner CIDEON creates and executes mix frameworks for market-driving MCAD, ECAD and SAP PLM frameworks. CIDEON Vault Professional Integration to SAP PLM empowers clients to share improvement documentation, SAP C_TADM55_74 Exam Braindumps materials ace information and bills of material between Autodesk Vault Professional and SAP ERP/PLM. SAP PLM capacities are straightforwardly open by means of the Autodesk Vault Professional UI.
