ECO
ECO
m_hermann
ECO
m_hermann
hi all,
I'm not a expert for ECO.
Customer asks if it's possible to get the ECO- Number to a document (which has a shortcut to ECO) property so that this property can use with the inventor revision table?
thx for help
Madhan_T
Hi, @m_hermann,
Currently, this is not possible out of the box. But, it is possible through customization. For the given ECO, we need to collect the associated DWG files (Inventor) and update the value of an iProperty (which can be consumed in Revision Table.)
You may wish to log this in idea station.
Madhan.
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
reidmatthew
Autodesk Support
Autodesk Support
Hi @m_hermann. I am just following up to see if you have any more questions or need clarification on anything @Madhan_T suggested? And to see if his suggestions helped you resolve your ECO questions.  If they do, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Matt R.
Product Support Specialist, Data Management
