Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Replace asm by older version
4 REPLIES 4
johan.degreef
133 Views, 4 Replies
What is the easiest way (without renaming/replacing stuff) to use an older version of a subassembly?
I want to use an older version of the pipe with 2*45° bends.
Many Thx
Inventor 20250, Vault Professional 2025, Autocad Plant 3D 2024
4 REPLIES 4
ihayesjr
in reply to: johan.degreef
Right-click on that version in the History tab and select Get.
The Vault status inside of the Vault client and Inventor add-in will show you are using an older version but you will be fine.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
johan.degreef
in reply to: ihayesjr
I think I did that, but no older version displayed. I want the subassembly to be an older version, so I selected the asm in Vault client, went to the history tab, selected the older version and did a get. Switched to inventor and did a refresh, but nothing changed.
ihayesjr
Did you have the assembly open in Inventor when you did the Get?
If so, it isn't going to overwrite the version in the workspace.
  1. Close the assembly in Inventor.
  2. Perform the Get in the History tab on the old version.
  3. In the Get menu, select the Force Overwrite option in the drop-down list.
  4. Open the assembly in Inventor
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
johan.degreef
Good point - will try it next time after closing assembly inventor.
Technology Administrators
