What is the easiest way (without renaming/replacing stuff) to use an older version of a subassembly?
I want to use an older version of the pipe with 2*45° bends.
Many Thx
Right-click on that version in the History tab and select Get.
The Vault status inside of the Vault client and Inventor add-in will show you are using an older version but you will be fine.
I think I did that, but no older version displayed. I want the subassembly to be an older version, so I selected the asm in Vault client, went to the history tab, selected the older version and did a get. Switched to inventor and did a refresh, but nothing changed.
Did you have the assembly open in Inventor when you did the Get?
If so, it isn't going to overwrite the version in the workspace.
