Manage Workgroup Replication
dmorse
Message 1 of 9
dmorse
I'm trying to enable Workgroup Replication, but am getting a permissions error. I get a Database server could not copy file to error, Please vereify if permissions and disk space allow this operation.
I have created a shared folder and added read/write permissions to current user(which also happens to be the replication user acct), AutodeskVault, and SQL Agent.
I am using the Replication User credentials when trying to enable workgroup replication.  Any help on this is greatly appreciated.
BTW - in the image attached that depicts the error, the folder \ADMS' does not exist yet.  The system is trying to create it.
___________________________________
Dave Morse, Sr. Technical Specialist
APPLIED SOFTWARE | Harnessing the Power to Go Further | 800.899.2784 | LiveLab Learning
Replies (8)
Message 2 of 9
Neil_Cross
Dave, have you applied object level permissions to that folder for those accounts, or share permissions?
Message 3 of 9
dmorse
Yes. It is unclear to me which users/accounts should have access to this folder, I have set the permissions for all of the following accounts to "Allow" for every category:
SYSTEM
Autodesk Vault
SQL Agent
VaultPro (this is my login account, and also the replication account)
Administrators
What else should I include?
Message 4 of 9
paul.gunn
When setting permissions on a share there are actually two places permissions need to be set. On the 'security' tab and then permissions on the share itself.
Have you set permissions in both places?
Paul
Message 5 of 9
dmorse
Yes, it is done in both locations. I've even made sure the child files and folders inherit the permissions, but I still get the same error. I was logged in to Vault as the administrator, and decided that maybe I need to be logged in as the Domain user. Still no joy.
Dave Morse
Technical Advisor
(Sent from my iPhone)
Enceptia
800.454.5499
Direct 210.892.8428
Message 6 of 9
Neil_Cross
Dave - it's a sledgehammer approach and definitely not recommended for final production use, but if you're just testing and want to get it up and running quickly, if you put the 'Everyone' group as full control over the share and at object level (security tab) that should get it rolling for now.  You can then troubleshoot the permissions later on.
Message 7 of 9
dmorse
Thanks. Will give that a try.
Dave Morse
Technical Advisor
Enceptia
800.454.5499
Direct 210.892.8428
Message 8 of 9
paul.gunn
Hi Dave,
The security requirement is for the replicating user and the user SQL server runs under. I suspect the later is what is giving you problems. This can be determined by looking in windows 'local services' and seeing who the SQL server service is running under. Historically this has been 'network service' however in doing a quick test here I see that SQL 2014 uses a different service user. So looking up the exact user is the best approach.
Paul
Message 9 of 9
dmorse
The Sledgehammer approach has worked. I can now move forward. Thanks for all the help.
