Times when Inventor crashes, my work is lost upon the last time I checked stuff into Vault. Also If I hit save from time to time, seems that when restarting and opening the assembly (from local!), the vault version is the one that I get...
Is this normal behaviour?
Open assembly from local should not replace files from Vault.
Unless Vault is setup that way.
If you "Get" the assembly from Vault then it could overwrite local files.
@Frederick_Law wrote:Unless Vault is setup that way.
Where can I check that?
I think it's similar to your other thread.
I think it's "Release bias".
Opening an assembly will use "Released" version.
