Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Layout - Detail View - But without the huge margins. Impossible?
4 REPLIES 4
EdvinTailwind
271 Views, 4 Replies
Using Vault 2023.1.1.
Why is there such huge margins (or paddings) in each row in Vault when thumbnails are shown? A third of the available vertical space is eaten by nothingness. 🙂 Can this be controlled somehow? I haven't found any setting related to this.
Some examples with the excessive spacing marked with yellow.
1. Without thumbnails:
2. "medium" thumbnails:
3. "Large" thumbails:
Labels (1)
4 REPLIES 4
CGBenner
in reply to: EdvinTailwind
@EdvinTailwind   Hi Edvin!
I don't believe there is any control other than the available sizes for the thumbnails.  Maybe there needs to be an Idea post on this?  What if there was a Word Wrap toggle, similar to Excel, so that text in the columns next to the thumbnails wrapped and filled the empty space?  Something like this?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
ihayesjr
Do you have Automatic column sizing turned on?
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
EdvinTailwind
in reply to: ihayesjr
I did! (until now, haha...). That did fix the problem, strangely enough. Thanks!
Why does a setting that controls COLUMN sizing make the ROW height/vertical padding change? Also, I see no reason why the thumbnails should have that excessive spacing, in any situation. Does seem like an undesired behavior to me.
Should I post a change request on the Idea board?
Did you intend to post an example/screenshot here? 🙂
ihayesjr
This is most likely due to the scaling that takes place when the Thumbnail is shown in the grid.
Even when you don't have "Automatic Column sizing" turned on, if you make the thumbnail column large enough, the spacing goes away. The grid does not have any controls to allow you to size the rows.
This image is with that setting turned off.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
