Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Inventor.exe restore old Vault Shortcuts.xml
11 REPLIES 11
Message 1 of 12
i_dubail
484 Views, 11 Replies
i_dubail
Dear all,
It seems that Inventor.exe access to my
%appdata%\Autodesk\VaultCommon\Servers\Services_Security_01_10_2023\192.168.67.118\Vaults\Vault\Objects\shortcuts.xml : see event logger below.
at this precise time, an old xml is "restored", and I loose my recent shortcuts.
Known issue ? Any solution ?
Dear all,
Tags (2)
11 REPLIES 11
Message 2 of 12
ihayesjr
in reply to: i_dubail
ihayesjr
Sorry, I don't understand that language, but it looks like this record in the event viewer is informational, and it recorded a successful access to the XML file.
Please correct me if I am wrong.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 3 of 12
ihayesjr
ihayesjr
Also,
Ensure you access Vault using this IP address (192.168.67.118) and not the server name.
If you changed to the server name, this shortcut XML file will not be used.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Also,
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 4 of 12
i_dubail
i_dubail
Hi Irvin,
Thank you for your reply.
In Inventor and in Vault Explorer I am logged in with the IP address.
While I was working, Inventor was able to access my shortcuts, you are right. But this removes my last shortcut. I can see it "flashing" in Vault Explorer: All the shortcuts disappear, then the old ones come back. So I'm missing the recently added shortcuts. Same problem for at least one of my colleagues.
Hi Irvin,
Message 5 of 12
ihayesjr
ihayesjr
Your original statement was that the old shortcuts are restored. Vault does not store your personal shortcuts.
What version of Vault are you using?
What is the date on the shortcuts.xml file?
Try this.
Open just the Vault Client.
Add a new short cut
Close the Vault Client.
The XML should update and have today's date and time.
Open the Vault Client again.
Is your new shortcut there?
What is the date and time of the XML?
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Try this.
Add a new short cut
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 6 of 12
i_dubail
i_dubail
Opening Vault client... Auto logon.
I add a shorcut : my shortcuts.xml has the time : ‏‎16:16:51. I make a copy, same time.
I close de Vault Explorer.
XML is still there, time :  ‏‎16:18:22. => You're right.
I open Vault Explorer, time : 16:18:22.
for this time, my new shortcut is still there.
The next time I'll loose a shortcut, I'll check the date and time of my file.
In my memory, when a shortcut is deleted, the old file is restored with the old time. Is it in cash memory in Inventor ?
Message 7 of 12
ihayesjr
ihayesjr
There is no "old file" to restore.
When you delete a shortcut, the XML file is updated with the changes.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 8 of 12
GunnarNilsson
GunnarNilsson
AFAIK the xml with the changes are written to disk when the Vault client is closed in correct order. If the Vault client crashes the changes created in the last session are not saved. Can that be what happens?
Message 9 of 12
i_dubail
i_dubail
I performed several tests.
The date of the xml is updated immediately when I add or delete a shortcut. If Vault crashes, my shortcuts keep.
Message 10 of 12
GunnarNilsson
GunnarNilsson
Ok, must be another xml I'm hunting for then, or the behaviour is changed lately.
Message 11 of 12
i_dubail
i_dubail
Hi guys !
I've just had the issue.
Finish my daily job.
Save, check in (in Inventor).
Close Inventor
=> I can see my Vault Shortcuts, in Vault "flashing". nothing during 1/2 second, then my new shortcuts are lost.
Time of my xml backup :  12:54:45
Time I close Inventor : ~16:15
Time of my Shortcuts.xml : ‏‎16:15:03.
Here is a comparison of my xml, and a screenshot of my Windows Explorer. Hope it helps !
Hi guys !
Close Inventor
Message 12 of 12
ihayesjr
ihayesjr
Please create a product support ticket for this issue.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
