How to merge 2 different vaults from 2 different AUTODESKVAULT instances
michael_kolominskyZT9WV
Our company has two AUTODESKVAULT instances on 2 different servers.
One instance has 4 vaults and the other a1 vault.
We would like to merge them into one AUTODESKVAULT instance.
I have found several articles.
One article suggest to use Data Transfer Utility:
How to merge Vault databases from different Servers into one (autodesk.com)
The other article suggest to use detach/attach option:
Migrating Your Autodesk Vault Server using ADMS Detach and Attach
Do you have suggestions on which option is more suitable?
Thank you
johan.degreef
As I remember it, you can't do that yourself. You need a certified Autodesk partner to do that for you.
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
GunnarNilsson
The first option is the only one that works in this case. The second option is just moving a set of vaults from one server to another.
And as Johan stated, you need assistance of an Autodesk partner.
