How to change language of ADMS Console / Vault server to English
adam_krugG5YNQ
Message 1 of 8
adam_krugG5YNQ
I installed Vault server but I used the Polish installer, now the server has Polish UI. How can I bring it to the default English?
Version 2026.2
Replies (7)
Message 2 of 8
ihayesjr
If this is a fresh installation with new vaults, the internal database information will also be in Polish. For example, property names. Regardless of the UI change, these will remain in Polish.
If this isn't a fresh installation, change the language in the OS regional settings to English. The ADMS Console will show in English, but this change will affect all application languages.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 8
adam_krugG5YNQ
hi Irvin,
Yes, this is a fresh installation, on a VM that will be only used for Vault Server. But I haven't created any Vaults there yet.
Must I now uninstall it, get the English installation files and install them? The OS (Windows server) is in English.
Message 4 of 8
ihayesjr
That Polish installer comes with English. Did you check the Region settings in the OS?
If that isn't working, then yes, you will have to uninstall and re-install English.
Irvin Hayes Jr
Autodesk, Inc.
Message 5 of 8
adam_krugG5YNQ
In Windows settings it all seems to be set to English US. Or do you mean some other OS settings?
But the UI for ADMS Console is Polish:
Message 6 of 8
ihayesjr
ok, it looks like you will have to download and install the English version.
Irvin Hayes Jr
Autodesk, Inc.
Message 7 of 8
adam_krugG5YNQ
Thanks.
I need to install specifically version 2026.2 . If I'm not mistaken, from Autodesk portal I can only get the latest version, do you know how could I get the original 2026.0, English installer? The 2026.2 patch I already have.
Message 8 of 8
ihayesjr
The Vault Server installer is always the RTM version (2026.0). You have to download it to install it.
Irvin Hayes Jr
Autodesk, Inc.
