File Path Errors
File Path Errors
File Path Errors
When we get things from Vault or Check Out through Vault it duplicates our working folder, and creates a duplicate folder under our working folder on Check In. When we Check Out through Inventor or the Vault Add-In in Inventor it creates the correct file path with no issues. Why is it doing this? See the picture for an example.
I can't enforce a single working folder yet, or ipj yet because we are still in the process of converging two physical locations to the same working folder and ipj protocol. I know this isn't the issue though because I had them enforced for awhile and it did the same thing.
My location employees open everything through Inventor and the Vault Add-In in Inventor, no issues.
The other employees at the other location use the Get feature in Vault then open through their local drive in Inventor. Lot's of issues. I am trying to break them of this formula, but you would think that this wouldn't happen.
Shouldn't the file path be the same either way?
ihayesjr
You will want to verify that the Project file that is being used is configured correctly.
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
