- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When we get things from Vault or Check Out through Vault it duplicates our working folder, and creates a duplicate folder under our working folder on Check In. When we Check Out through Inventor or the Vault Add-In in Inventor it creates the correct file path with no issues. Why is it doing this? See the picture for an example.
I can't enforce a single working folder yet, or ipj yet because we are still in the process of converging two physical locations to the same working folder and ipj protocol. I know this isn't the issue though because I had them enforced for awhile and it did the same thing.
My location employees open everything through Inventor and the Vault Add-In in Inventor, no issues.
The other employees at the other location use the Get feature in Vault then open through their local drive in Inventor. Lot's of issues. I am trying to break them of this formula, but you would think that this wouldn't happen.
Shouldn't the file path be the same either way?
