2018.2 Copy Design - Unhandled Exception error
karthur1
Mentor Mentor
karthur1
When I use the "new" Copy design, I get an "unhandled Exception" error when I try to resize the UI.  If I select a file and place it in the grid, I no longer get the error.  See screencast video below.
I am using Vault Pro 2018.2 Update (Build 23.2.3.0)
Kirk
Senthil_Kumar
@karthur1 Kirk,
I am unable to get that error in my Windows 10 systems. I tried Vault 2019 on Windows 7 as well and not seeing the error there as well.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
karthur1
I just did a rebuild on my Vault Pro install. Issue persists.
For what its worth, I still have 2017 Copy Design installed.  Tried the same workflow with it and no error.
Kirk
Senthil_Kumar
Is it just your machine?
Senthil Kumar
Autodesk, Inc.
karthur1
As far as I can tell, yes, just this one machine.  However, this is the only Win 7x64 machine that I can find here.  Everyone else is Win10 here.
I just tried it again this morning after a reboot and problem is still there.  Doesn't really cause any problems that I can see.
Senthil_Kumar
Thanks for the reply Kirk. I will also try with some other Win 7 machines to see if i can reproduce it and update you.
Senthil Kumar
Autodesk, Inc.
