Exporting Advanced Search Results with Job Processor
kirkk
kirkk
I have setup 4 advanced searchs of change orders that I export the results to excel sheets.  The sheets then feed a Microsoft Power BI dashboard.  The data is currently updated manually by clicking through and exporting to overwrite the sheets.  I want to setup the job processor to do this once an hour.  Is this possible? Or some other solution...Thanks for the help.
ihayesjr
@kirkk
Have you tried using the Vault Data API with the PowerBI sample app?
Irvin Hayes Jr
Principal Product Manager
Vault - Under the Hood Blog
kirkk
I haven't.  Does that connect Vault and Power BI directly?  I didn't think that was possible because vault didn't allow it.  I am using Power BI desktop.  Would that make it so I don't have to perform the advanced searches?  And would it be live updates?
Kirk C Koons
Principal Engineer
DMC
ihayesjr
It is a sample of how to use it, but you will need to make some code changes to get what you want. It uses the Vault API, and you must be on Vault 2025.2 at minimum.
Irvin Hayes Jr
kirkk
Our team is currently on Vault Professional 2024.4.1 Can I just update my seat to 2052.2 and not mess everyone else up?  If so, I'd like to give it a try.
