Disable Data Standard for Inventor Frame Generator and Pipes and Tube
ritthaler
Message 1 of 8
ritthaler
how can i disable the VDS for Inventor Frame Generator and Pipe and Tube?
In the file ,datastandard.InvAddIn.dll.config' i can disable the VDS for Inventor Commands. But what are the right commands for this specific funktions?
In use is Vault and Inventor 2025.2.1
Thanks!
Replies (7)
Message 2 of 8
CGBenner
@ritthaler
Hello.  Can you explain exactly what you are trying to do?  Disable these two modules completely?  May I ask what issue you are trying to solve with this?
Chris Benner
Message 4 of 8
ritthaler
Hello, I would like to use the Data Standard in Inventor, but not for the Frame Generator or Piping Tool. I don't want to deactivate the frame generator or piping tool but only the data standard for these tools. Problem is the vault numbering. I can place frames without the VDS in a assembly but if i check in to vault the VDS/Vault numbering came up and rename the frames. Thats the reason why i disable the VDS for Frame Generator and Piping tool. Another option would be to suppress the vault numbering.
Message 5 of 8
ritthaler
Hi, thanks for answering.
In the link disable Data Standard for spesicif Inventor commands was something about eventwatcher. I installed the developer tools but there is no manual for using the eventwatcher. How can i use it for figure out the right command?
Message 6 of 8
CGBenner
@ihayesjr @gandhey
Hi, do we have any ideas on this question?
Chris Benner
Message 7 of 8
ihayesjr
Message 8 of 8
CGBenner
@ritthaler
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
