Default Comment based on Transition
River.EngumYTTWH
River.EngumYTTWH
It seems the only way to change the default comment, when transitioning states, is to change it for the entire final state.
Is there any way to have the default comment be based on the transition instead of the final state?
johannes.bauer
Autodesk Support
Autodesk Support
In the lifecycle definition you can change the default comment
https://help.autodesk.com/view/VAULT/2026/ENU/?guid=GUID-1625AB3D-3F2F-4823-B120-268FC6A3713E
HTH
-Johannes
Customer Technical Success
River.EngumYTTWH
So the answer is no, I cannot have comments based on transition rather than final state. Thanks!
johannes.bauer
Autodesk Support
Autodesk Support
No you can add to every transition a default comment see my screenshot
HTH
-Johannes
obulesub
Hello, @River.EngumYTTWH ,
Just checking in—did the responses shared by @johannes.bauer help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Obulesu | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
(Obulesu Bodika)
