Message 1 of 9
- Mute
- Permalink
- Report
In version 2023 using the open with vualt command, after changing the display method inventor closed without any message, or errors appeared in the connector. Two versions have passed I have 2025 autodesk does nothing about it.
Error and then crash
I will also add that the most important information in the logs is probably:
System.InvalidOperationException: Object is currently in use elsewhere.
at Autodesk.DataManagement.Client.Framework.Vault.Forms.Controls.VaultBrowserControl.getPropertyValuesResults(...)
E
