Crash inventor using open from vault command.
idealogicERZYZ
Message 1 of 9
idealogicERZYZ
In version 2023 using the open with vualt command, after changing the display method inventor closed without any message, or errors appeared in the connector. Two versions have passed I have 2025 autodesk does nothing about it.
Error and then crash
I will also add that the most important information in the logs is probably:
System.InvalidOperationException: Object is currently in use elsewhere.
at Autodesk.DataManagement.Client.Framework.Vault.Forms.Controls.VaultBrowserControl.getPropertyValuesResults(...)
E
Replies (8)
Message 2 of 9
ihayesjr
@idealogicERZYZ
Did you create a support case for this?
Irvin Hayes Jr
Principal Product Manager
Vault - Under the Hood Blog
Message 3 of 9
idealogicERZYZ
Yes.
Case #: 24156745
E
Message 4 of 9
idealogicERZYZ
Hello to all interested,
Update 2025.3 to vault has been released and the bug is still not resolved.
The problem has existed since version 2023 and nothing is being done about it.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Enabling-thumbnail...
E
Message 5 of 9
ihayesjr
@idealogicERZYZ
Many of us have tried to reproduce this crash, but we have not been able to.
Irvin Hayes Jr
Message 6 of 9
idealogicERZYZ
I am attaching a detailed description from the error window.
E
Message 7 of 9
ihayesjr
I believe we have all of that information from your case. However, without a way to reproduce the error, we are still unable to find what is causing the problem.
Irvin Hayes Jr
Message 8 of 9
ihayesjr
Hi, we have finally found a way to reproduce the crash and we are working on a fix.
Irvin Hayes Jr
Message 9 of 9
idealogicERZYZ
The problem has not been solved. The case has been open for weeks and no one is doing anything about it.
E
