Message 1 of 17
- Mute
- Permalink
- Report
When I make a copy using the copy design fonction, the exclusion does not work.
Exclude doesn't work on part files the way you expect.
Please see following to understand its usage
Or
Yogeshwar
(Vault team)
May I know what do you expect here ?
Actually there are factors to restrict exclude of part files from assemblies. Constraints etc which vault cannot control.
There is an idea station post :
Yogeshwar
(Vault team)
content center parts are automatically excluded, if not checked.
Content Center parts are not excluded.
No parts or subassemblies can be excluded in Copy Design because it breaks the model.
Exclude can only be used on parent documentation files. If this is set on any other file in the structure, that file will be reused during the copy operation.
If exclude doesn't work, if exclude "breaks the model", it shouldn't be an option. If exclude can only be used on "related" drawings, which can be deleted manually without issue, exclude is useless. If exclude is greyed out, I expect a note that says why.
Years have gone by and still there isn't an option to disregard folder structure for copy design.
Years have gone by and file status options are greyed out, text is coloured red, without explanatory note.
Years have gone by and still there isn't an option to shift-select files, or select folders, during copy design. Each file has to be modified individually.
Years have gone by and still you can only initiate a copy design exclusively with vault.
1st edit:
Years have gone by and still, during copy design, new file names, new vault path, file status, just gets reset or modified without warning or message.
Years have gone by and still there are random restrictions everywhere that make no sense.
Outright embarrassing.
2nd edit:
Very 'funny' message during copy design stating "Model cannot be copied", reason: "Part already written on disk". Looking in the Vault AND local project folder and there's absolutely nothing there, zero files, nada, nothing. What is this absurdity? Can restart all over again and must change the path for every single file individually. Again.
Ridiculous functionality.
Can you tell me what version of Vault you are using?
In Copy Design, Click View -> Panels -> Folders.
Option 1:
Option 2:
There are two ways Copy Design will give an explanation on failures
1. The error dialog gives a list of all errors that you can copy and place in Excel to keep the list.
2. If you have closed this dialog, you can hover your mouse over the red "X", a tooltip will appear with the error message.
Copy Design can be initiated inside of Inventor while you have the model open.
Right-click on the model in the Vault Browser and select Copy Design.
Files will get reset based on what is happening with the child or parent model.
They can also be reset using the "Reuse" or Reuse Branch" options.
If you have some example videos showing what you are experiencing, maybe I can help.
2nd edit:
If you can share some video examples of these, maybe I can help.
Thank you Irvin for your efforts.
It seems that the difference between your Vault and mine is that I'm using basic 24 and you're using Vault super ultimate expert plus 2025, because all this functionality you're showing is absent in my version. We've upgraded from vault basic 21.
Unfortunately, I cannot afford to spend an afternoon providing examples and videos when I have very low hope in succeeding in the end.
That version of Copy Design is now available in Vault Basic 2025.
