Hello Rick,
When you upgraded to Vault 5, did you upgrade to Inventor 11 as well? If so,
consider migrating the CAD files and libraries. You could also uncheck the
Prompt to Save for migration option in Inventor. Are these iParts that are
prompting for Check Out and update? Have the paths changed in the ipj file?
Once you check these out and save, does it keep prompting you? Let us know.
Brian Schanen
Product Designer - Data Management
Manufacturing Solutions Division
wrote in message news:5171554@discussion.autodesk.com...
We just upgraded to Vault 5, for some reason it is now always asking us to
check out library parts - and this is causing major problems when someone
else needs to open a library document in there assembly. Is there some
setting that we have to adjust to prevent this from happening?
Rick
