check out file into default design data folder instead of the folder define in the vault ipj file.
jean-marie.nazaret
jean-marie.nazaret
Hello everybody,
I'm JM CAD mentor of the FRC team 5553. We start to use Vault and we have some issue.
First, i want to say thank you to the autodesk community for the help.
So, we have a strange problem.
We install Vault Basic on a specific windows server, we define  a vault ipj , some folders, etc...
and, when we make several check out/check in with the same file, sometime this file is copied into the local default design data folder and  not into the worspace folder mapped with the vault tree .
I don't understand why.
I'm sure i make something wrong but i don't know what.
thank you for your help.
JM
Gabriel_Watson
Perhaps your user was using the wrong Inventor project file, or tried to Get a bundle of files where some were inacessible/invisible to them?
gandhey
A video will help. Otherwise user might have downloaded the files to design data folder by mistake too.
Yogeshwar
(Vault team)
jean-marie.nazaret
jean-marie.nazaret
Thanks for your answers.
I checked, everybody used the same project file ( stored in Vault ) and for all of us the working Folder is the same...
Just a silly question, but all the files ou get from Vault are supposed to be download into the working folder setup up in Autodesk Vault Basic ? ( File > Set Working Folder ... )
Otherwise, the problem i described earlier stills here but i have some more details:
We have an assembly and 1 part stored into the Vault.
Assembly-tst.iam
axe.ipt
A/ i  i get those files with the "get" functionnality and check them out. The files went to my local folder ( the good one ) and i open them with file/open as usual. It worked fine. I checked them all in.
B/From Inventor i use "Vault > Open" to select a file from Vault and open it.
I choose the assembly and i get a message: "File Not checked out . Do you want to check them out ? ..." ( which is normal, the file was not checked out )
i select Yes and i get an empty dialog box without the possibility to select and click OK.
... So impossible to open the file from Vault :(.
It's not the same problem as previous but maybe the 2 problems are connected ?
Regards.
