Check in fails - Files not recognized as the same
FilipeMais
FilipeMais
Hi everybody,
I need to Check in two assemblies (step files attached).
After check in the 1st Assembly, Vault says the files of 2ndAssembly already exist.
Yes, it is true.
There are the same files in both configurations, but doesn't Inventor understand it?
Any one have you a solution?
Thanks in advance.
Kindly,
Filipe
Error message during check inError message during check in
ihayesjr
While the files already exist, they are in different folders and you have enforce unique file names enabled.
You need to make sure that your assemblies are using the same subcomponents in the same folders.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
FilipeMais
Thank you ihayesjr
According to your post, I inserted the Step file in the same folder where were all the other parts, I opened it, I saved it and I checked in successfully!
Thank You!
All the best!
